Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /www/htdocs/w0058ef5/ausfahrten/includes/pnAPI.php on line 670
Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /www/htdocs/w0058ef5/ausfahrten/includes/pnAPI.php on line 573
Deprecated: Function ereg_replace() is deprecated in /www/htdocs/w0058ef5/ausfahrten/modules/Xanthia/pnclasses/Xanthia.php on line 562
Thema: Biker Termine aus der SceneIn diesem Thema sind folgende Beiträge:
Deprecated: Non-static method ADOConnection::UnixTimeStamp() should not be called statically, assuming $this from incompatible context in /www/htdocs/w0058ef5/ausfahrten/includes/classes/adodb/adodb.inc.php on line 2813
Deprecated: Function ereg_replace() is deprecated in /www/htdocs/w0058ef5/ausfahrten/includes/pnLang.php on line 971
Deprecated: Function ereg_replace() is deprecated in /www/htdocs/w0058ef5/ausfahrten/includes/pnLang.php on line 972
Deprecated: Function ereg_replace() is deprecated in /www/htdocs/w0058ef5/ausfahrten/includes/pnLang.php on line 973
Deprecated: Function ereg_replace() is deprecated in /www/htdocs/w0058ef5/ausfahrten/includes/pnLang.php on line 974
Deprecated: Function ereg_replace() is deprecated in /www/htdocs/w0058ef5/ausfahrten/includes/pnLang.php on line 991
Deprecated: Assigning the return value of new by reference is deprecated in /www/htdocs/w0058ef5/ausfahrten/modules/pn_bbcode/pnuserapi.php on line 435
Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /www/htdocs/w0058ef5/ausfahrten/includes/classes/safehtml/safehtml.php on line 366
Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /www/htdocs/w0058ef5/ausfahrten/includes/classes/safehtml/safehtml.php on line 367
Ron ::: 19. Okt 2004 ::: 4435 Aufrufe
 Zwei Tage waren mal wieder nicht genug. Die Zeit ist nur so verflogen! Auf dem Forumstreffen in der Villa Löwenherz in Lauenförde kamen 16 Leute zusammen. Zwei nette (und lange) Abende, zwei verschlafene Frühstücke und eine super Ausfahrt bildeten das Programm. Hier erst einmal alle Teilnehmer. Von oben links nach unten rechts waren dabei: Dirk, Ulf, Helmut, Thorsten, Dani, Phillip, Chris, Steffi, Angelika, Ron, Jörg, Stefan, Volker, Jürgen/NRW, Jürgen/Mosel, Rolf. Die ersten Berliner trafen sich am Freitag zwar recht pünktlich aber mit der Abfahrt klappte es dann doch nicht ganz so. Wir kamen etwa eine Dreiviertelstunde später auf die Piste und vertrieben die Zeit .....(s.weiter)
Seite << | 1 | 2 | 3 | 4 | >>
Deprecated: Function eregi() is deprecated in /www/htdocs/w0058ef5/ausfahrten/footer.php on line 30
Deprecated: Function ereg_replace() is deprecated in /www/htdocs/w0058ef5/ausfahrten/modules/books/pnblocks/randombook.php on line 53
Deprecated: Assigning the return value of new by reference is deprecated in /www/htdocs/w0058ef5/ausfahrten/modules/dpStaffStatus/pnblocks/dpStaff.php on line 40
Deprecated: Assigning the return value of new by reference is deprecated in /www/htdocs/w0058ef5/ausfahrten/modules/dpStaffStatus/pnblocks/dpStaff.php on line 113
Benutzer: |
Heute neu: |
0 |
Gestern neu: |
0 |
Total: |
383 |
Letzter: |
| Noiajf |
Online |
Benutzer: |
0 |
0 |
Total: |
0 |
Mitglieder online |
Es sind keine Mitglieder online |
